07-28-2021 12:51 AM
Greetings everyone!
I recently was assigned to handle a small beach resort consisting of 15 caravan rooms in beach front a 2 floor restaurant in the middle.
Currently our network uses Unifi controller, switch and 7 access points.
I faced multiple issues with the restaurant connectivity with the waiter tablets losing connection frequently which affects operation. I tried multiple settings that the Unifi team recommended me but nothing fixed that issue which is pushing me to look for an alternative solution from Cisco before we proceed with buying 15 access points for each of our caravan rooms.
What would be the most suitable ceiling mount access points for restaurant and in wall access points for the caravan rooms?
We intend to increase our caravan rooms to up to 40 in the near future so we need to have controllers that will handle more access points and clients.
07-28-2021 12:53 AM - edited 07-28-2021 02:32 AM
I always have one answer to anyone asking this sort of question: Get a wireless site survey done properly.
07-28-2021 01:06 AM
The current access points provide good bandwidth and signal, but the issue is that the tablets that are used by the restaurant for making orders use an application that frequently detects "no internet connection" when there is a fluctuation in the wifi connection.
07-28-2021 01:17 AM
As suggested - if you do not like business effected and rely on wireless for business toi run
- do proper Wireless survey
- what devices you have and expected to connect, before hand test it.
- make sure fat roaming tested (Hope tablets are roaming i guess here) - or fixed PoS ?
- how bout the same application if you test using Wired network - is this works all time ?
07-28-2021 02:02 AM
The statement above contradicts to the statement below:
The resort has already made a big mistake by "designing" the WiFi on the cheap. Now the resorts wants to play "double or nothing" and gamble some more by not heeding recommended best practice of getting a proper WiFi site survey done professionally.
