Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
504
Beginner
brand new wap561 green light keep flashing
got a brand new wap561 for a customer and out of the box, the green light keep flashing after 1-2 minutes and will never stop.
checked (and changed) poe adapter (twice) network cables, power cable.
I tried to do a factory reset (holding the reset for +10 sec.) and still the same
any idea???
1 REPLY 1
Highlighted
Re: brand new wap561 green light keep flashing
I think you are mentioning about the 'Power' LED, if the 'Power' LED is flashing with green color that means the AP is "Upgrading firmware or acquiring an IPv4 address.".
In case the device is connected to any DHCP server then you can disconnect that link and verify the status. You can check the rechability to the default management IP of that AP 192.168.1.245.
You may refer the link...
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap5x1/quick_start/guide/WAP_551_561_QSG.pdf
