I have been having some connectivity problems and one suggested solution was to upgrade networking firmware. I did this for our router (Cisco RVS4000 v2) and it didn't help, so I moved on to the wireless access points (two WAP4410N). Before doing that, I also reset both to factory default settings - neither would respond to pressing the reset button but it seemed to work using the web interface for both.
Before I did anything to the WAP4410Ns, I noticed they were connected in B/G/N-Mixed mode to channel 6. Now the wireless network mode is stuck on Disable. I can choose B/G/N-Mixed from the dropdown list, but can't choose a channel - the dropdown list for that is empty. And if I try to choose Save after choosing B/G/N-Mixed, it reverts to Disable.
Sorry if this is a dumb question. I'm not a pro. Thanks in advance.
