12-21-2010 07:40 PM
I have a working WAP2000 that won't accept the 2.0.3.4 upgrade file. After selecting the file and pressing the UPDATE button, I receive the following error:
The webpage at http://192.168.254.246/upgrade.cgi might be temporarily down or it may have moved permanently to a new web address.
Below is the original error message
Hardware Version: | 1.0 |
Software Version: | 2.0.0.5 |
Local MAC Address: |
12-21-2010 07:57 PM
Tried with IE 8, FF 3 and Chrome. Same results in all.
12-22-2010 01:07 PM
Hi John -- Sorry I can't replicate this. The 2.0.0.5 download is working for me. Please try clearing your cache and cookies and donwloading from http://www.cisco.com/cisco/software/release.html?mdfid=282414134. Login is not required.
Let us know if it works.
Stephanie Reaves
Cisco Small Business
12-28-2010 06:07 AM
I have the same problem here. the original firmware is:
Hardware Version | Rev.01 |
Software Version | 1.0.16 |
Is there an other way to upgrade the firmware?
I also tried version 2.0.0.5, same problem.
the link in the previous post does'nt seem to work...
greetings
12-28-2010 08:06 AM
Jan, I was able to solve my original problem by doing the firmware upgrade from another PC. Why the original PC which had done 1 previous upgrade would not work, I don't know. Try it from a different PC.
12-29-2010 03:15 AM
Hi, John.
I tried with serveral computers, different operation systems nothing worked until i diisconnected the power from the device after the WAP2000 boots up again it's possible to upgrade.
thx,
Jan
