Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
900
Beginner
Cannot connect to cisco router with window 8.1
I have Window 8.1 Pro and my router is Cisco DPC3825 Wireless Router. tried logging into http://192.168.0.1/ but it does not connect to it.
14 REPLIES 14
Hi zerotosran, TRY https:/
Hi zerotosran,
TRY https://192.168.0.1 I think its will  work.
If not let me know..
kafi
Beginner
it does not work, it just
it does not work, it just hangs.
Hi zerotosran , Change your
Hi zerotosran ,
Change your Java Setting.
Go Java>java>view>run time parameters> -Xmx256
ok
now try
thanks
kafi
Beginner
still doesn't work.
still doesn't work.
Hi what is the ping result???
Beginner
I am sorry I do not know how
I am sorry I do not know how to ping java
or if you were referring  ping to the gateway ip is 1ms
Hi If you use Internet
If you use Internet Explorer please ensure that both your Security Policy
and your Privacy Policy is set to MEDIUM.
Beginner
Hi Zerotosran, Are you logged
Hi Zerotosran,
Are you logged onto the LAN or WLAN? What is your gateway address that shows up by running ipconfig from the command line?
Usually your gateway will be the location to check for an http/https server.  I hope that helps.
patrick
Throwing packets since 2012
Beginner
I am connected through the
I am connected through the lan, my gateway address that shows up is 192.168.0.1
Please Check connection Via
Please Check connection Via Ping.
Check Compact ability of the browser.
Check with https:
Beginner
https://support.microsoft.com
https://support.microsoft.com/en-us/kb/2749073?wa=wsignin1.0
could this be the problem with my case?
Highlighted
Beginner
Try using http://192.168.0.1
Try using http://192.168.0.1   ; this will work
Jerry Paul
www.thenetworkhardware.com
Beginner
does not work.
does not work.
Participant
Hi,How is the pc connected to
How is the pc connected to the router? If it is connected directly please make sure that you are able to reach the router by issuing the command "ping 192.168.0.1" from a command line terminal. To open the command line terminal press windows button+r then write cmd and finally enter. If after that test the result is positive and the reachability is successful you should be able to access to your router by writing the ip address 192.168.0.1 at the address bar. Instead if the connection betwwen the pc and the router is not direct please advice the topology. Finally make sure that the ip settings of your pc is set manually just in case the dhcp server is not enable on the router, set the ip to something different than 192.168.0.1 and the subnet mask 255.255.255.0, you don't need to set up the default gateway because you are on the same subnet of the router.
Regards | Aref.
