Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
1664
Re: Captive Portal Guest Login redirecting not working in mobile
I hope you are using DHCP server in your Network to provide the IP address to the wireless clients, so on the DHCP pool you can use that DNS. Also on your Router WAN interface (via which the WAP is connected) you may use that DNS.
Beginner
I'm just guessing here. Some mobile phones have to options to improve the Wi-Fi throughput by augmenting it with the 4G connection. Is there a chance that this option is enabled and the phone is bypassing the Wi-Fi in favor of the 4G, at least for the DNS?
Beginner
Did you try taking DNS out of the picture by using the real private IP address instead of by name?
It will be better to test the redirection by disabling the ‘Mobile Data’ option on the Phone and using Wi-Fi only to conclude.
As I have mentioned earlier, I have verified the redirection on the old android version 7.1.1 (with Samsung make Phone) and the latest android version 9.x (with Xiaomi make phone) and redirection is working fine on both the cases. I was using ‘cisco.com’ as the redirection page.
