04-16-2022 06:03 PM
I am having major issues setting up a CBW140AC-B out of the box. I have it plugged into the PoE port of my router and per the instructions, I waited until it cycled to flashing green light. Then again per the instructions, I am supposed to connected to SSID CiscoBusiness-Setup. However the SSID never shows up. I scanned with both laptop and smartphone. I have unplugged and plugged the AP in again. It then goes through a never ending cycle of of red, amber, and green. I am having great difficulty finding troubleshooting steps online, I can't even find how to factory reset the thing. Do I hold down the mode button or just press it briefly? Sorry I am very lost.
Solved! Go to Solution.
04-18-2022 11:57 AM
May be worth installing 7.0 and testing it, or opening a TAC case to help fix the issue?
04-18-2022 12:00 PM
04-22-2022 01:39 PM
I was able to download 7.0.1 and got it updated. The AP seems to be working so far. Not sure if this is expected behavior but now the FP switch ports are all blinking in unison about 3 times a second. I am not seeing anything in the status page of the FP.
