Hello all,
In short: I have two Cisco Small Business AC140 wireless access points that get stuck flashing red after zero day setup. Neither will broadcast after initial restart. Both accept factory reset and bring up zero day setup.
Specifics:
I go through the zero day setup, assign a static IP, assign primary WAP name, assign wireless name, and reboot. In the 5 minutes I have before reboot, I can see the WAP is broadcasting the assigned wireless name, I can even connect to it. Once the WAP reboots, it stops broadcasting, cannot be pinged, nor does it respond to ciscobusiness.cisco - regardless if I use wired or wireless connection, both devices flash red at this point. This is why I think I configured something incorrectly.
If I let the DHCP assign an IP, the result is the same. When I scan my network for devices, the assigned IPs are not recognized and do not receive an expected label of live, dead, or no reply. The IP is simply ignored, leaving a gap. ie it is assigned #4 and the scan reveals 1, 2, 3, 5, 6, 7. I let the device sit for 30 minutes thinking it was downloading firmware, sadly no change. All I really can do is confirm the factory reset procedure works. Any suggestions would be greatly appreciated!
Thank you
Edit:
LED colors: Reboot; fast blinking green; solid green; slow blinking green; green/amber/red twice, then continuous blinking red.
