cisco wap reboot schedule
monconstruction
I would like to schedule a reboot of my WAP 581.  I check the box to schedule and set days and hours.  It works the first time and never again for some APs.   When I look at the settings after the first reboot, the "schedule reboot" is unchecked and the days & hours are set.   Any ideas?  Should I set at the command line or does it work better with a certain browser.   Something so basic is not working !!!
boatanas
Dear Customer,
What is the firmware version you are currently running on your WAP581? Here's a link to the latest image: https://software.cisco.com/download/home/286314835/type/282463166/release/1.0.1.3?i=!pp
Borislav Atanassov
Cisco Small Business TAC
Yes using the latest firmware.
Dear Customer,
Please send me a private message with your Cisco ID and the serial number of the device so I can open a service request for you.
If you don't have a Cisco ID, please register here: https://identity.cisco.com/ui/tenants/global/v1.0/enrollment-ui
Thank you!
Borislav Atanassov
I have several WAPs. Here is one of them that is not auto rebooting - Serial
Number: DNI2141A050
