03-19-2020 11:42 AM
i bought a 2x WAP371's for indoor and 2 571E's for outdoor to upgrade my house's wifi (was using providers modem-wifi) i hoped that my devices would have an easier time roaming around with 802.11R..
weirdly enough all my 3 devices connect on 5ghz and are still stuck on wifi A , so max sync 54mbps , and only if they are connected with the 371.. if they are connected to the 571E's they do go to AC 866mhz sync
the RSSI is -55 so im pretty close to them , i checked with 2 laptops, both have the intel 7260AC chip and are set to prefer 5ghz.
all accespoints have latest firmwares ( 1.3.0.7 for the 371's)...
the security code is set to WPA2-AES only (TKIP disabled)
i cannot find what im doing wrong with tthe 371's...
04-12-2020 04:52 AM
Hello @koolsbart41685,
My name is Anton and I am part of the Cisco SMB Support.
By saying "roaming around" do you mean that you have set up same SSID on all WAP's?
If so I assume you will need to configure WAP devices in cluster or in WDS mode as described in the links below:
Also is recommendable if you set same SSID for both 5 and 2.4 bands to enable band steer.
Kind Regards!
04-20-2020 07:17 PM
10-04-2020 06:12 AM
in the QoS , see if WMM if checked on or off
