02-04-2012 11:24 AM
ap541n in cluster access point exists a master ?
02-06-2012 09:31 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
My apologies but I am not really sure of what your question is. Could you please restate it for me?
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
02-06-2012 10:38 AM
Dear Eric,
with cluster solution do i need to configure one access point as master and the others as slave?
In thi8s case, the access point release is 2.0 (1) and connected with UC540. The lan interface on UC 540 is configured as access point vlan native 1. This system doesen't work correctly. Phones spa525g2 are not always connected, i nedd to reset very frequently the access point.
thank you in advance
Giovanni
02-06-2012 12:13 PM
Hello Sir,
With the AP541 N there is not an option for Master vs Slave the Clustering option is really only for allowing the clustered AP541N to share configuration settings and changes.
With using this in a UC540 Network I would suggest calling in and opening a case with our UC support group here in the small business support center.They have good experience with setting up the AP541N in a UC network.
Cisco Small Business Support contacts:
http://www.cisco.com/en/US/partner/support/tsd_cisco_small_business_support_center_contacts.html
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
