03-25-2019 04:15 AM
i'm having problem to turn on cluster mode on my WAP 361.
here is the msg poping up at the bottom of the page on all WAP :
it worked for a while and suddenly had this on all WAP
And the most curious thing is that i bought 3 new WAP last week and try to setup it on a new cluster and had the same thing.
All WAP are on the last firmware 1.1.0.9.
Don't know how to resolve the bug
Thanks for your help.
Chris
04-02-2019 05:08 AM
Dear Chris,
Could you please verify if all access points have the same part number - for example WAP361-E-K9 or WAP361-A-K9?
Are all of them connected to the same VLAN?
Thanks.
04-02-2019 06:19 AM
04-02-2019 07:04 AM
Chris,
Thanks for your feedback! Now, if possible, can you remove the Dlinks temporarily and try clustering again?
Either way, I think we should open a service request for you, so please send me your CCOID and a serial number of one WA361 as a private message.
04-04-2019 08:06 AM
Even with the dlinks disconnected, i have the same result.
I just received new access points and tried to enable clustering on a new cluster on the first one and i have the error message.
I think it appeared when i turned all my access point (dlink and cisco) to manage them on vlan 1.
Before that, each cluster were on a separate vlans and worked.
Maybe it's a lead ?
What's a CCOID ?
04-04-2019 08:41 AM
Chris,
Yes, this may have to do with the management VLAN being the same. Anyways, this issue requires further investigation. Please register yourself here https://identity.cisco.com/ui/tenants/global/v1.0/enrollment-ui?ui_locale=en_US and send me a private message with your Cisco ID and the serial number of your access point. I will make sure we open a service request for you.
Thanks.
