Freeradius + WPA2 authentication
oncledave
I have been trying to use a freeradius server to authenticate wifi users with WPA2 entreprise.
The AP connects to the radius server but the users are always refused.
Are there attributes ( like Cisco-AVPair ?) that need to be added to the user in freeradius ?
Or is there something missing in my AP config ?
When I test the authentication from my ASA firewall, it tells me that it works well.
Thanks in advance for the help.
Aironet 1042 config :
version 12.4
no service pad
service password-encryption
hostname XXXXXX.local.org
logging rate-limit console 9
enable secret 5 XXXXXXX
aaa new-model
aaa group server radius rad_eap
server 192.168.1.6 auth-port 1812 acct-port 1813
server 192.168.1.7 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap local
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid Wifi
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
username XXXX password 7 XXXXXXXXX
username XXXX privilege 15 password 7 XXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
broadcast-key vlan 1 change 300
broadcast-key change 300
ssid Wifi
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Wifi
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
ip address 192.168.1.7 255.255.255.0
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip default-gateway 192.168.192.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
  nas 192.168.1.7 key 7 XXXXXXX
  group localusers
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.192.7 auth-port 1812 acct-port 1813 key 7 XXXXXX
radius-server host 192.168.192.6 auth-port 1812 acct-port 1813 key 7 XXXXXX
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
0 Replies 0
