07-31-2017 09:51 AM
I'm using an SG300 as a DHCP server for my wireless clients. I'm noticing that every now and them my client gets a DHCP address from the proper pool, but are getting their default gateway from a different pool. When i clear the old stale/expired bindings from the pool and reset the NIC, the client will get the correct DHCP address/DG. The current code is 1.4.2.4. All scope addressing is configured correctly as well.
I did see a bug that was supposed to be fixed in this version that sort of matches my issue, but not exact.
Issues Addressed in Version 1.4.2.04
• Switch as DHCP server always assigns its IP address as default router option (option 3) even if this option is not configured in DHCP pool. If other IP address is configured,
Solved! Go to Solution.
07-31-2017 01:33 PM
Hi Chris
there are multiple bugs for dhcp on these smb switches that seemed to have been passed through the firmware versions I would recommend using an actual server if possible just for the dhcp service , you could try to downgrade but from what I have seen though this forum(you can search dhcp sg300 in the search bar) there seems to be issues in every version unlike the catalyst switches where its more stable
07-31-2017 01:33 PM
Hi Chris
08-01-2017 05:46 AM
I do have some older smb switches that don't experience the same issue. They do run an older code though.
08-01-2017 06:23 AM
I would use that then if its working fine on dhcp if a server is not an option.
at least until a newer fw version comes out for your newer smb platforms
08-01-2017 07:41 AM
