H Reap installation in remote site. VLAN issue
harish_chopra1
My querry is, if I have a AP I am installing it in the remote site, then on the switch what should be vlan id I should keep where the AP will be hooked up. My connectivity from Remote site to Data center is Layer 3, MPLS network.
pls. suggest.
harish_chopra1
whatv vlans we should allow in trunk port ?
in my scenario, we have MPLS network in between.
Pls. explain if possible. Thanks !
hreap AP tries to get an ip from connected switch's native vlan and try to join wlc.
hreap locally switched wlans require wlan to locally switched vlan id mapping on all hreap APs, you need to allow those vlans on the AP connected switch for local data switching. if you've 3 hreap locally switched wlans and you prefer to use one tagged vlan then allow that tagged vlan along with the native on the trunk.
