10-07-2009 11:40 AM
I´m trying to change the default password in autonomous AP521G, the CCA2.1 sent me errors when I tried to change, or create another user with Privilege 15.
10-07-2009 12:22 PM
10-07-2009 01:37 PM
Hello Glenn, It´s not a password recovery problem. I´m trying to change the default Cisco/Cisco username/password, but the Config Assistant doesn´t allowed.
I´m going to try with CCA 2.0 version instead 2.1.
Best Regards.
Hector
10-08-2009 02:11 PM
Now with CCA v2.0 I created a new user and delete default user/password.
Thanks.
10-09-2009 09:30 AM
Glad to hear you found a work-around. I'll make sure the CCA production team is aware of this issue.
Best Regards,
Glenn
