Lightweight AP521 - Dot11radio shutdown
Benjamin Waldon
I am trying to install a AP521 with a WLC526. The AP is in lightweight mode. I have configured the SSIDs on the WLC, and the AP is registering with the WLC, but it says that the dot11radio on the AP is "operationally down". I can't find where to enable it. I can't open a web browser to it, the CLI is incomplete, and CCA doesn't give me any options to configure it. I was able to configure it (ie static ip) through the WLC's web interface.
The issue occurs whether I use the ac adapter or the power injector.
This is the output of when it it boots up:
    *Mar  1 00:00:05.621: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
    *Mar  1 00:00:07.024: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
    *Mar  1 00:00:08.204: %SYS-5-RESTART: System restarted --
    Cisco IOS Software, C520 Software (C520-K9W8-M), Version 12.4(10b)JX, RELEASE SOFTWARE (fc1)
    Copyright (c) 1986-2008 by Cisco Systems, Inc.
    Compiled Sat 02-Feb-08 19:24 by prod_rel_team
    *Mar  1 00:00:08.204: %SNMP-5-COLDSTART: SNMP agent on host AP2 is undergoing a cold start
    *Mar  1 00:00:08.222: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
    *Mar  1 00:00:09.065: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
    *Mar  1 00:00:09.222: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
    *Mar  1 00:00:10.065: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
    Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
    *Mar  1 00:00:27.248: %LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER
    *Mar  1 00:00:27.248: %LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER
    *Mar  1 00:00:27.248: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
    *Mar  1 00:00:28.699: Logging LWAPP message to 255.255.255.255.
    AP2>
    %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_CURRENT_PORT inline power source
     %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
     %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
     %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
     %LWAPP-5-CHANGED: LWAPP changed state to JOIN
     %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
     %LWAPP-5-CHANGED: LWAPP changed state to CFG
     %LWAPP-5-CHANGED: LWAPP changed state to DOWN
     %LWAPP-5-CHANGED: LWAPP changed state to UP
     %LWAPP-3-CLIENTEVENTLOG: AP has joined controller KerrWLC
     %WIDS-6-ENABLED: IDS Signature is loaded and enabled
     AP2>
Any help would be much appreciated. I am opening a case with the TAC, but I have to get some paperwork straightened out first. I think it's just a setting somewhere, but I am not sure where.
Ben
Hi Ben,
Given the anture of your problem, TAC is the way to go.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Benjamin Waldon
Actually, as it turns out a simple "enable" through the web interface on the 802.11g radio fixed the issue.
