Linksys WET54G connected to HP 420 AP change key types
peter.karlberg
Linksys WET54G connected to HP 420 AP change key types. it works for a day or so and suddenly it change the key-type from WPA-TKIP to WEP. communication fails of course. Restart the units will make it to work again sometimes you will have to restart it several times. some ide what the problem may be ?
streaves
Sorry we don't have an answer for you. Recommend you try the Linksys by Cisco forums at http://forums.linksysbycisco.com. Hopefully you find the solution there.
