Mounting Brackets for WLC526
Benjamin Waldon
I ordered a WLC526 for a customer. Howevever, it didn't come with brackets to mount it into a standard 19" rack.
I called our distributer support. They said that it's intended to be a desktop unit. However, it has screw holes on the side of it.
Does anyone have a part number for brackets to mount the WLC526 into the rack?
Ben
Michael Adler
The 526 controller doesnt have its own brackets, but the controller housing is the same as the UC500 housing, so you can order the brackets for the UC500.
ASA5505-RACK-MNT     for Rack
ASA5505 -WALL- MNT   for Wall
Mike
Michael Adler
Mike
Thanks alot.
Those part numbers are actually for the asa, but i hear they will work on the WLC526. The actual part number for the UC500 rack mounts is ACS-UC500RM-19=.
I found that the "UC500" part number quite a bit less expensive than the ASA part number.
Ben
