Multiple CBW Masters
tominski
Is it possible to have multiple CBW Masters on the same network?  It appears that the MAC address used is static and hence two is an issue?
Many thanks
Tom.
CoreyP319
Hey Tom,
It is not possible to have multiple primary APs (formerly called 'master') on the same subnet, or network.
Have a great day.
Corey
11 Replies 11
CoreyP319
Hey Tom,
Have a great day.
Corey
Hi Corey,
I have CBW 140AC, once configured as a primary AP and add subordinates working fine but if the main internet goes down and come back the AP are not working and the LED lights are blinking red. What's the issue and solution?
Hi Shuja,
@shuja Tahir
Blinking red can indicate a IP assignment issue. See the article here for more details:
https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/kmgmt-2934-cbw-startup-led-status-codes.html
Thank you.
...and how many APs can be managed by the "master"?
Ciao
The primary AP can manage up to 50 subordinate APs depending on the configuration and environment.
thanks Corey!
another Q: the cbw APs can be managed by a wlc? like ct5508 or 9800? Thanks
CoreyP319
Hey Vincenzo,
Happy to help. These CBW devices are of a controller-less design so there is only the primary AP management to be handled. If you would like more of a 'hands on' approach you could use Cisco Business Dashboard or the CB mobile app.
Have a great day!
Corey
great! so in case I need a "plan B" I can't managed these APs to convert in a sort of lightwave APs and mage these by a traditiona wlc, right?
These CBW devices cannot be converted into the hardware they are based off of. That hardware was also a controller-less design. There is only management via: the Web UI, CBD, mobile app.
have a good day you too
