03-29-2014 01:21 PM
Hi to all
I recently purchase a Wireless Access Point (AIRCAP 3702E-E) with 4 antenna, i will use this device like wifi hotspot in my home.
I would like to upgrade it but i see two kind of AP IOS :
What are the difference ?
In case of Lightweight AP IOS Software will be the one to choose, i have multiple IOS :
Someone can tell me what is the difference between these two versions ?
Best Regards.
Elrick.
03-30-2014 07:07 AM
Hi Elrick,
Cisco AP AIRCAP3702E is Cisco enterprise unit. Cisco small business support WAP4410N, WAP121, WAP321, WAP551, and WAP561 AP. However I will answer your questions.
Lightweight AP ISO you can use it ONLY if you connect AP to wireless controller
Autonomous AP ISO for manage and modify AP by it self not required wireless controller.
Moh
03-30-2014 07:07 AM
Many thks, so the Autonomous release is the good one for me.
I just install it.
I would like to link my AP to my Cisco router, do you know where i can get some info for a correct setup ?
Regards.
03-30-2014 02:32 PM
Hi Elrick,
Do you know your router mode?
Moh
03-30-2014 02:46 PM
My router is a 2821.
03-30-2014 03:58 PM
Hi Elrick,
this is correct support community forums for routers
https://supportforums.cisco.com/community/5991/wan-routing-and-switching
here support community forums for AP
https://supportforums.cisco.com/community/4931/wireless-mobility
I know how to config your router and AP however I am in different department.
Moh
