Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1079
yesenia-m
Beginner
Problem with WAP440N- continually renewing IP
They have 2 AP WAP4410N in which there are two different SSID on VLAN, the DHCP server is a switch, when connected to any network delivered the correct address but after a short time, about 2 hours, the Current transition in the computer you are renewing the IP and this time goes offline causing disconnection to different applications.
I'm considering putting the command Router (config-dhcp) # lease {days
[hours] [minutes] | infinite}, leaving infinite value.
What else could this situation happening in the network, including about 2 or 3 users online at the same tiempo.os
thanks
regards
1 REPLY 1
jurodri3
Beginner
Hello Ms. Martinez,
In order to help you with this issue we are going to need to know what kind of the device is the DHCP server, and help you with the proper configuration,
Could you please let us know the type of device and details about the current configuration?
Thank you,
Diego Rodriguez
Cisco network engineer
Thank you
