Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1439
Trinetcorp
Beginner
Remove username on captive portal?
Is there any way to get that removed and just have the greeting, terms, and connect button?
I've changed it now to more of a spam authentication where they just enter a random word in there now. But I'd like to remove it entirely if possible.
Thanks.
6 REPLIES 6
Prithvi Manduva
Hello Brett,
You can try using the verfication as guest where there will be no authentication required.
http://www6.nohold.net/CiscoSB/Login.aspx?login=1&pid=4&app=search&vw=1&articleid=2937
Let me know if it works!!
Prithvi
Thanks, Prithvi Please mark answered and rate for helpful posts.
Thanks Prithvi, I did have that already selected but the field still shows up on the captive portal page. Anything else?
So....that doesn't work, what can we do next?
Purchasing
Beginner
I'm looking to do this exact same thing.  Basically I don't want the guess wireless users to have to enter credentials, but instead just accept terms.
Just a tip in the right direction would be appreciated now. I was sold on this feature and it has yet to deliver between this, the ios 404 error, and the fact that the agreement window is limited to only 520 characters and it doesn't like anything other than text.
Sad cisco experience so far.
Trinetcorp
Beginner
Any updates on this with the new firmware release?
