03-07-2012 08:02 AM
I've been asked if 2 clusters of AP541N can be associated to the same VLAN.
In reality, I need to put 12 ap's in the same cluster, in the same vlan, but due to the limitation of 10 ap's per cluster, this is my workaround.
I am not familiar with those ap's, so I am looking for information, before I make my recomendation to my client.
Cheers,
VM
03-07-2012 02:13 PM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
I really dont see an issue with this. The cluster only effects the management of the device and should have any bearing on what device is on what LAN.
Two AP541N can associate to the same VLAN. The Cluster name should be of no factor.
Please keep us posted.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
11-28-2012 05:33 AM
I forgot: Thanks!
