two WAP4410N AP help for setup
kenteo001
Our company recently purchased two WAP4410N AP.
We got 2 buildings in our office, I label it as Location A and B.
The following image is our company network diagram.
We would like to make both AP to use same SSID, what is the best practise to configure it? Same SSID, same password and even same channel (channel 11)
We set the AP in building A, as AP, and Building B as repeated, we found it Building B signal is not stable enough, sometimes the Wireless LED is off by itself. We not even able to access via web browser. It's like hang.
Can any expert guide us for this.
lariasqu
Hi Ken, thank you for using our forum, my name is Luis I am part of the Small business Support community. I am glad to assist you with your configuration, bellow you will see an article with some advises in order to set your roaming, also some tips in order to improve your wireless signal.
https://supportforums.cisco.com/docs/DOC-31044
https://supportforums.cisco.com/docs/DOC-29821
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
