Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
4177
Highlighted
Beginner
Re: WAP 150 losing gateway
**ATTENTION CISCO**
We need a fix to this. You say call in, but then ask for a smartnet contract number which we do not need for a small business product.
Highlighted
Beginner
we are also facing the same issue on our WAP :
We lose connectivity but we still can manage them within the same vlan.
If you want to open a case on it, go through the chat and ask them to open a case for you. I did it this morning and worked fine for me.
Regards.
Highlighted
Beginner
Actually logged a call on Friday and they accepted without a Smartnet contract. Another WAP 150 had same issue. Been escalated internally as looking like Software Bug. If get a solution I'll post it up.
Highlighted
Beginner
Bug CSCvg69584
Beta available from Cisco to address.
Workaround: you can set the IP address to DHCP.
I called in without smartnet contract and they dealt with me very well.
Highlighted
Beginner
Wow!
Thanks a lot.
Beginner
I had previously tried the DHCP settings, assuming it to be a workaround, but still had the same issue on a reboot.
Highlighted
Beginner
I reported this problem to the Cisco Support Center.
The ticket was opened.
I'll report it as soon as I have progress.
Highlighted
Beginner
I got new firmware. WAP not losing gateway when WAP reboot.
New firmware was delivered to me. It is not published
Highlighted
Beginner
Wow, finally! So when and how are we going to receive this new firmware? This has been a problem for far too long.
Highlighted
Beginner
i have the same problem, how can i get the latest firmware,
gsdroubi@hotmail.com
Highlighted
Beginner
My version is 1.1.0.9_big-hammer.
This issue is cleared.
Highlighted
Beginner
This firmware is 1 year old and published
On cisco site
Highlighted
Beginner
i have the latest firmware,it is not losing gateway,but the startup is not right since if I remove the
power (POE or Adapter) ,it operates normally without any problem ( I have 10 AP having this issue)
any suggestion for a solution??
Highlighted
Dear Gsdroubi ,
Please send me your Cisco ID along with a serial number of your WAP150 and I will make sure that a service request is opened for you.
Thanks.
Borislav Atanassov
Cisco Small Business TAC
Highlighted
I'm having the same problem with three units, every time the devices reboot the gateway is lost. Firmware version 1.1.0.9.
Would you care to see that a service request is opened for me as well?
Thanks.
S/N: DNI2026A221, DNI2113A01M and DNI2113A064.
Cisco ID: danielssferreira
