08-29-2012 07:13 AM
I see new firmware is available fo rthe WAP 321.
I tried to read the release notes from the link in the rupper right hand side of the scren bt get a 'Forbidden file' message. I am logged into Cisco.com .
Solved! Go to Solution.
08-29-2012 07:40 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
The release notes for the WAP321 and the WAP121 are the same. Please try this link:
I was able to get to this. I will have the other link investigated.
Eric Moyers
Cisco Network Advanced Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
08-29-2012 07:40 AM
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
08-29-2012 02:55 PM
Thanks Eric, That link works just fine.
Clive
08-29-2012 11:03 PM
Eric,
I note this is just a MIB files update for WAP321 - any status on when the new firward will actually be available?
Cheers,
Dale Bentley
08-29-2012 11:31 PM
Hi Dale,
Please go here to download the f/w:
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
08-29-2012 11:48 PM
Thanks Cindy,
Somehow I ended up in the MIB download section however never realized my mistake.
I have successfully downloaded and applied the latest firmware to one WAP now for testing.
Cheers,
Dale.
08-30-2012 08:06 AM
When implementing this new firmware do I have to reset the AP back to Factory Defaults first?
08-30-2012 08:36 AM
The reason that Cisco recommends this on occasion, is when there is an added feature or layout change, the old configuration will not always match up with the new GUI, which in some circumstances can cause issues.
It is not specifically stated that with this firmware that you have too. However as a general rule I always have customers that I am working with do a factory reset. Doing so does not hurt anything.
Hope this helps.
Eric Moyers
