WAP 581 Captive Web Portal authentication slow
monconstruction
When I enable local authentication for the guest wifi, it takes a long time for the page to load (cisco captive page).   When authentication is turned off, guest wifi connects and users can start browsing the internet.
I created a guest account, configured to use local database.  I have also tried to use no authentication but have users hit the web portal page first to check connect, same problem.   Any ideas or settings to change?
boatanas
Dear Customer,
The issue you are experiencing requires a more in-depth troubleshooting. I would therefore advise you to open a service request with us. Please find your contact here: https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Borislav Atanassov
Cisco Small Business TAC
