Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
1543
Beginner
WAP121 after 1 day AP unresponsive
After 1,5 day the WAP121 unresponsive.
After a reboot I get back to the admin site and the clients can connect again and everything is ok again.
My Network:
1 SG300-10MP FW: 1.3.0.59
2 WAP121 FW: 1.0.3.4
The WAP121 is connected to the SG300 and get power over him.
I have the same problem if it uses power from the AC adapter.
In the support log I found the following entries:
crashdump1:
Software Version: 1.0.3.4
Crash Log:
Uptime of the AP: 1 Days, 15 Hours, 17 Minutes and 0 Seconds
CPU Unable to handle kernel paging request for process = swapper and pid = 0
epc == c0517fe0, ra == c054c564
Stack Trace:
[<00000000c054c564>] - wlc_scbfree+0xe8/0x3b4 [wl]
[<00000000c054d030>] - wlc_userscb_alloc+0x2c8/0x2d0 [wl]
[<00000000c054d7dc>] - wlc_scblookup+0x11c/0x1c0 [wl]
[<00000000c057af84>] - wlc_ap_authresp+0x68c/0x9d0 [wl]
[<00000000c053425c>] - wlc_recvctl+0x1158/0x28b8 [wl]
[<00000000c0675984>] - wlc_recv+0x5f8/0x808 [wl]
[<00000000c067e698>] - wlc_dpc+0x6c8/0xb30 [wl]
[<00000000c0678360>] - wl_dpc+0x50/0x164 [wl]
[<000000008002effc>] - tasklet_action+0x70/0xf4
[<000000008002e980>] - __do_softirq+0x80/0x110
[<000000008002ea78>] - do_softirq+0x68/0x70
I hope someone can help me.
greeting
Claus
Everyone's tags (5)
16 REPLIES 16
Highlighted
Beginner
Sounds very similar to my ongoing problem, although I can get up to 3 days out of them sometimes.
There has been no solution.
Beginner
HI All, If issue resolved
HI All,
If issue resolved please give me good rate smiley
if issue still occur Please call our center at 1-866-606-1866
Moh
Beginner
I am having the same issue.  The device is own, but IP connectivity is not working.  I tried disabling spanning-tree by configuring the device as an edge port.  Any update if this issue is resolved?
Beginner
HIMatt, Do you have static IP
HIMatt,
Do you have static IP or unit get dynamic IP from DHCP server?  can you ping unit?
Moh
Beginner
HIMatt,
Moh
Beginner
I have two of these devices,
I have two of these devices, both have static IP addresses.  I cannot ping either device until after a reboot.  I have tried disabling spanning-tree and setting the device as edge port.  The switch ARP table does not show the MAC address of the device.  The switch ports show up and connected.  I have now hard coded the speed and duplex to 100 full on both devices.  The Manamgent IP is in a VLAN, and I have not tried moving it to VLAN 1.  But making the change would cause some security issues.
The SSIDs are being broadcast, but when attempting to connect the message unable to join network is displayed.  We have tested with MAC, Win7, Android and iOS devices and have the same issue with all devices.  I have not yet tried changing any of the advanced wireless features.
Beginner
I too have the same problem
I too have the same problem on my 3 wap121
they become unresponsive after approximatively 24 hours uptime.
firmware version 1.0.4.4, power from POE, 3 different SSIDs enabled, WPA-AES security
for now i've configured my switch to disable the ports for 5 minutes at night to reboot the APs
Beginner
Hi Claus, Please do some
Hi Claus,
Please do some changes in your AP and monitor unit 24 hours. Access unit GUI and do this following
go to Wireless --> Radio
in redio change
Channel to 1, 6, or 11
change Beacon Interval to 400
change DTIM Period to 4
Lefact Rate Sets: uncheck 1 up and down, uncheck 2 up and down
click SAVE
Moh
Beginner
Hi Moh I tried the settings
Hi Moh
I tried the settings you suggested on one of my WAPs, and it has now an uptime of more than 2 days, never had more than 36 hours before.
I keep monitoring it and i'll let you know in two more days
Thanks for your help
Regis
Beginner
Did you ever get this
Did you ever get this resolved? Can you confirm the aforementioned fix?
BF
Beginner
unfortunately, i haven't been
unfortunately, i haven't been able to get this problem resolved. With these settings, my APs are working a little longer but they finally are unresponsive.
I configured my poe switch to disable the port at night so that the APs reboots every night.
Beginner
I'm sad to say that in the
I'm sad to say that in the end the solution was to throw all of our WAP121s in the trash where they rightfully belong, and we bought from Aruba instead. Since then we haven't had a single issue.
Rising star
My name Eric Moyers. I am an
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to hear that you are experiencing this issue. If you devices are in Cluster Mode or Single Point Setup, I would ask that you disable that as a test. Also, please go to the Wireless-Bandwidth Utilization tab and disable Bandwidth Utilization and as a last modification please go to the Wireless-Radio tab and under Legacy Rate Sets supported and basic disable rates 1, 2, and 5.5.
If this does not improve your issue, please call our support center and open a case so that one of our engineers can work directly with you.
Eric Moyers
.:|:.:|:. CISCO | Eric Moyers | Cisco Technical Support |
Wireless and Surveillance Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Beginner
In researching this issue I
In researching this issue I came across another forum and the solution was to rollback firmware to factory version 1.0.0.3.
I have not tried it yet, but am curious if you ever attempted this fix?
Thanks!
BF
