Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
269
Highlighted
Beginner
WAP121 upgrade failing, not using BIN, failing using TAR
I get the message "Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields." when I try upgrade the firmware,
I am not unpacking the .tar, I'm using it just as it is downloaded from cisco.com.
I have single point setup with 4 WAP 121s. And it fails the same way on each one.
Please advise.
Cindy
Everyone's tags (2)
1 REPLY 1
Hello Cindy,
Hello Cindy,
Thank you for contacting Cisco support community center. I'm sorry that you are having the inconvenience mentioned.
Are you trying to upgrade using HTTP or TFTP?
Which web browser are you using for the upgrade? Have you tried a different browser?
If a different browser didn't work, I would suggest to disable the single point setup and test if the upgrade is successful.Just in case, I've included below a guide with the steps needed to upgrade the firmware.
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=53283703d9ce41f8889737b8605e0ce1_Firmware_Upgrade_on_WAP121_Access_Point.xml&pid=4&fcid=&fpid=&slnid=5
If you are still having issues with the upgrade, could you please attach a screenshot of the error received?
If I can be of any further assistance, please, let me know.
