WAP125 firmware upgrade failed
V-BA
I've just upgraded my WAP-125 to firmware 1.0.2.0, and then I've no longer access to the device via the web interface. Nothing happen after entering login and password.
I've performed a reset to factory settings, the problem remain the same.
Is there a way to flash from scratch?
thank you for your help, regard's
