WAP200E and Cisco Wireless Control System
yves.gouverneur
Hi.
I have a customer with a linux OS machine running Cisco Wireless Controll System.
He needs are to add a new wireless AP with the following features :
- compatible with most laptops
- exterior conditions "resistant" (sun, rain...)
- reasonnable performance (the AP would be a a roof with people on the roof itself, max distance : 15 meters, no walls)
AND
Which product would you recommend ?
I saw the WAP200E but I have no idea
- if it is compatible with Cisco Wireless Control System
- what antenna(s) to buy
Leo Laohoo
Hi Yves,
The WAP200E is not compatible with the WCS.
1.  How high (in relation to the client) is the AP going to be installed?
2.  How is the AP going to be installed?  Will it be hanging down?
3.  Do you need Cisco CleanAir?
HI,
WAP200E is not compatible with Wireless controller systems.Because LWAPP protocol is not supported by WAP200E.
Antenna HGA9N(HighGain Omni-Directional Antenna) is compatible with WAP200E.
