10-02-2012 08:03 AM
Our iOS6 devices cannot connect to our Cisco Wi-Fi access points using our guest network settings, which involves a captive portal where they must enter their email address. When they select the guest network, they get the screen shown at the bottom of the screen. Prior to iOS6, they'd get the web page where they enter their email address and accept our terms of use. This is happening both on upgraded devices and iPhone 5 devices. We haven't changed anything with the access points.
10-04-2012 10:52 AM
Same problem happening to me. just did a new installation with 10 access points and this is what happened. Posted in other discussions and no fix has been given as of yet.
Jeff
10-05-2012 06:20 AM
I have the same Problem with iOS 6. Windows 7 works fine with IE. Android too.
Only iOS 6 brings the 404 after i tried to connect to the wlan.
Its a new wap321 with 1.0.1.10
Jörg
10-05-2012 06:52 AM
We tested with iOS6 and it works here. We just have to make a new web request. Just opening safari doesn't do anything, it just sits there.
When we opened a new tab or page, then tried going somewhere, it worked.
It doesn't however, as the image shows, do the auto popup of the logon. If I was trying to get on wifi and use an app, this would be a huge thing. Still needs some work.
11-02-2012 05:03 AM
When i connect to the wlan with the cp then a popup comes on top.
I click the Homebutton and change to safari but the wlan was changed to a second one or will disconnect.
11-02-2012 05:02 AM
I have now the update for ios 6.0.1 installed.
When i connect to the WLAN the 404 page comes again.
12-04-2012 07:20 AM
Exactly same problem! Somebody try to open a case on cisco? Its a very important issue!!
12-05-2012 08:44 AM
I have opened a case with Cisco and went over all the testing I have done. (
Devices on 5.1.1 or under work, IOS 6 and above do not.)
Here is their response:
"We were able to replicate the issue reported in our labs and our software developers are working towards a resolution"
I have also called Apple and they suggest having all the clients restore their devices to factory defaults and trying again haha.
I will keep you posted when I hear back from the Cisco Engineers.
12-07-2012 02:08 AM
For sure the problem is on Apple side.. But! Maybe cisco can add a function to grant some URL bypassing the catpive portal. So we can add somes URL like intranet http://sharepoint.myserver.local or www.apple.com/library/test/success.html
It will be a good function...
12-10-2012 05:33 AM
FYI i try to connect with some Samsung Galaxy device! SAME PROBLEM !!! BUT on samsung device we can go to the portal page connecting on the local AP adress then we can access internet...
02-15-2013 02:45 PM
This issue has persisted for far too long without redress.
To anyone experiencing this issue: there is no fix. Please establish a Cisco ID, call Cisco and get a ticket #. Report it here or on the other two related threads at
https://supportforums.cisco.com/thread/2163439 and
https://supportforums.cisco.com/message/3836229
It seems that they are only going to fix this issue if the number of support tickets reaches a sufficient number...apparently long-standing, well-supported outcry on the forums is wholy insufficient to inspire actual resolution.
03-06-2013 07:16 AM
New Firmware fixes this issue.
It will be released soon. I have just tested it with iphone 4s & ipad on ios 6.1.
02-09-2015 08:06 AM
03-09-2015 07:53 AM
03-11-2015 09:04 AM
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to hear that you are experiencing this issue.
While what I am fixing to share is not in any way a great solution, It can be utilized as a workaround.
With the WAP321, after trying a few different scenarios that didn’t work. I simply created two vlans, leave the Untagged vlan as main vlan and changed the Management vlan to the second. I then attached the guest SSID to the Management VLAN. This allowed me to authenticate to my guest captive portal and get an IP and get out to the internet. The Main SSID still worked normally.
Now for some caveats:
Problem: If a wireless client knows the IP of the WAP and the username and password they could get into the WAP.
Solution: Setup Management Access Control to an IP outside the DHCP scope for that VLAN and have a Strong Password.
Problem: Management of the WAP321 can only be from an IP on the Management VLAN. (In my case 2)
Not the very best solution, but the only workaround I can come up with for now.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
