11-07-2013 09:49 AM
I have a Wap321 installed in my network. IP: 192.168.0.36 - VLAN 1
If I'm in the local area network, I do not have any problem to use the wireless.
I just added a guest VLAN for people who need Internet connection without LAN access. So I setup a second SSID and tag it with vlan 50. I can access to Internet. But If I want active the captive portal, I'm unable to access to it because the adress is in the VLAN 1 (or 192.168.0.36).
How I can setup my Wap321 to have the captive portal in the VLAN 50, not in the VLAN 1?
Thank you
Alex
Solved! Go to Solution.
11-16-2013 11:53 AM
Hi Alexandre,
For interVlan setting on ISA5510, yes same security settings is the first step for allowing this feature to work. This article will help you configure InterVlan routing.
11-07-2013 01:51 PM
Hello Alexandre,
If you have a router upstream, please make sure that you have enabled inter-vlan routing in there. Also, on the WAP321, please configure the router's VLAN 1 IP address as the default gateway. With these settings, you should be able to use Captive Portal for both VLAN 1 and VLAN 50.
Hope this helps.
Nagaraja
11-08-2013 05:36 AM
Hello Nagaraja,
My router is a ASA5510... I know, it's not a router! How I can enable inter-vlan routing? It is the same security levels settings? beacause I already enable this settings...
The default gateway of my WAP321 is the IP address of my router on the VLAN1 (192.168.0.1).
Thank for your help
Alex
11-16-2013 11:53 AM
Hi Alexandre,
11-20-2013 11:00 AM
Thank you Ismael... very helpful!
