WAP321 captive portal
sweekiat
HI,
My office planing to set up the captive portal for guest access.
the captive portal configuration is completed but I fail to access to the SSID with the captive portal user parameters password.
currently my office have 3 unit WAP321 ,is that possible my laptop was confused which AP should point to? and its that I need repeat to carted the captive portal user and group for every AP or its will auto sync to other AP?
my company did't create any vlan the subnet is 255.255.255.0
romcewan
Hi Sweekiat,
I understand that you have issues with your Captive portal, we will need to check and verify the configuration on your WAPs, I encourage you tou give us a call at 1866-606-1866 open a ticket and any of our Engineer will be more than glad to help you. About the password, try a simple password first like Test123, don't forget to call us.
Thank you
