01-18-2016 02:49 PM
I have a 3 clustered WAP321 WiFi access points. Several times a day my wireless clients loose connectivity. They stay connected to AP but no they can't reach DHCP server or other hosts on the network. The only way to fix a problem is to power off one specific AP. As soon as it's down connectivity is restored. Do I have a defective wap321 and if yes - how do I test it?
Oleg
01-18-2016 03:02 PM
Is there any newer firmware for it? I would start there.
01-18-2016 03:10 PM
It's at the latest firmware.
01-18-2016 03:13 PM
If all of the APs are identical, and only one is having an issue - then it suggests that one has a fault, most likely a hardware issue.
I would just go replace it. It's not worth the time looking into it further with an almost certain result.
