I have a WAP321 I am trying to set up. It's connected to gi1/23 and the switch system mode is set to router. The rest of the network works just fine.
I have an SG500-28p and the port is configured as:
interface gigabitethernet1/23
spanning-tree portfast
spanning-tree link-type point-to-point
macro description ap
switchport trunk allowed vlan add 20-22
macro auto smartport type ap $native_vlan 23
VLAN 23 is my management/default vlan
DHCP for vlan 20 is on a microsoft domain controller
DHCP for vlan 21 (the voice vlan) and configured on the UC560
DHCP for vlan 22 is configured on the UC560 as well
On the WAP321 wizard, configured IP address on my management vlan and also configured the default SSID on that vlan. That works. (I plan to remove that one) Then I add the two SSIDs for vlan 20 and 22 (private and public access) and I can't associate to either of the two additional SSIDs. I haven't configured any other settings beyond the wizard and adding the other two SSIDs. I do want cisco mobile ios (jabber) to work on the private network and also do have a couple spa525g2s that need to connect wirelessly.
Thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. I found this information regarding association Vlan-SSID:
STEP 1 Select Wireless > Networks in the navigation pane.
STEP 2 Select the Enabled check box for the VAP you want to configure.
—Or—
If VAP0 is the only VAP configured on the system, and you want to add a VAP, click
Add. Then, select the VAP and click Edit.
STEP 3 Configure the parameters:
VLAN ID—The VID of the VLAN to associate with the VAP.
You can get more information in admin guide from your WAP321 http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf, in page 74. If you have any question just let me know.
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
