Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
249
Beginner
WAP321 Corrupt Image
as described in the german quick guide, only the ethernet led is flashing quickly, seems like a bad image. Also checked with a sniffer, no traffic on the ethernet port. Thanks a lot!
PID VID: WAP321-E-K9 V01
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/quick_start/guide/WAP_121_321_QSG.pdf
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/quick_start/translated_pdf/WAP_121_321_QSG_de_DE.pdf
5 REPLIES 5
Highlighted
Re: WAP321 Corrupt Image
Flashing Ethernet / LAN LED indicates transmitting / receiving data on that interface. And after a new firmware installation if the power light is flashing quickly that indicates bad image.
What is the firmware version you are using on the mentioned WAP321-E-K9 V01 model?
Beginner
the currently installed firmware is 1.0.6.5 i guess. Only the ethernet led is flashing, the power(using ac) and wifi led are both dead. cheers!
Are you able to access the GUI of the mentioned WAP321 ?
For further troubleshooting you may contact us and open a service request with us following the below mentioned link…
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Beginner
Nope. It's completely dead.
The AP has no service contract, so should i throw it away?
Sorry for the inconvenience you are facing. As mentioned before, please open a service request with us following the below mentioned link…
We will check for the possibilities to assist you in this case.
