09-03-2013 05:35 AM
My WAP321 connected to a office switch A.
WAP321 wifi clients unable to get DHCP
Clients wired to switch A can recieve DHCP.
Using firmware vesion 1.0.2.3
I'm perplexed still.
09-03-2013 07:58 AM
Tried LAN->LAN and IPv$->'Untagged VLAN' unchecked this. But lost control of WAP321 So ....
Had to reinstall firmware. Now usiung latest 1.0.4.2 but still no DHCP request are working across the wifi connection.
Any ideas Cisco Team?
09-06-2013 11:19 AM
Hi Harvey
Can you please provide the information about switch you are using..
Punith Kumar Neelam
09-10-2013 05:53 AM
Hi Harvey,
Please go through the following post on similar prob, might help.
09-12-2013 12:42 AM
Hello Harvey,
We need a little bit more information.
-What kind of switch do you have?
-What Vlan(s) are you using?
-What ip address did you configure for the WAP321?
-Are the devices able to actually connect to the SSID but just not get an ip address?
-If you plug a PC into the same port that you are plugging the WAP into is the computer able to pull an ip address?
It should be pretty straight forward at this point though. As long as the AP is able to reach your DHCP server then the AP is just going to be a passthrough for your clients when it comes to getting a DHCP address.
Clayton Sill
09-12-2013 04:39 AM
Due to a earlier print issue I've reset the WAP321 and uploaded the latest firmware. Which seems to have fix the printer issues but not fix my DHCP request issue.
Been doing some more digging and drilled it down a little further.
What I have is unmanage switch(no vlan) which is connected to WAP321(with static IP).
I'm able to wifi SSID connect ok with the OSX laptop i.e. request DHCP work.
Now i'm running a VM on this laptop ( Virtual Box running FreeBSD )
VM/FreeBSD boots but is unable to get DHCP requests.
If i connect the laptop to another wifi AP point the same virtual box VM/FreeBSD - i'm able to get DHCP requests
(note: AP different make & connected to same unmanage switch)
Seems to surgest WAP321 could still be the issue.
Although (Virtual Box + FreeBSD VM) could also be an issue - which is beyond this forum.
09-12-2013 08:15 PM
Hello Harvey,
This article might offer some help.
IPv4 Settings Configuration on WAP121 and WAP321 Access Points
