11-30-2012 09:29 AM
MyWAP321 is dropping connections at least once a day since upgradiing to firmware 1.0.1.10. before the upgrade I had no problems and I have another WAP321 with firmware 1.0.0.3 that never drops connection. Is anybody else having this problem since upgrading?
11-30-2012 12:26 PM
Here is a similar report;
https://supportforums.cisco.com/message/3796107#3796107
This is a newly released firmware, I haven't heard anything internally about this yet. Let's keep an eye out and see if many other have something to say. I will also check our internal database to see if any cases have been made about this.
Edit- I have checked our internal case history for all wap321/121 cases in November, currently I do not see any cases for dropping connections or general connectivity / flakiness.
Please upgrade to 1.0.2.3 and see if the issue persists.
-Tom
Please rate helpful posts
Message was edited by: Thomas Watts
06-09-2013 02:33 AM
Hi ,
Ive just installed this WAP 321 wiht Radius server authentication.
I have the firmware version 1.0.2.3 and this WAP is now having Connection dropout and dosent connect again.
I have to do re try for several times and again it starts working.
Please see the log and advice me what is happeing inside it and why this connection is not staying persistent with the associated wireless clients.
Jun 9 2013 20:07:25 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:36 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:36 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:35 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:35 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:17 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:17 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:16 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:04:16 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:56 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:56 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:53 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:53 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:52 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 02:00:52 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:22 | info | hostapd[1241] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:21 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:21 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:20 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:20 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:18 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:59:18 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:57:27 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:39 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:39 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:38 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:38 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:37 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:55:37 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:36 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:36 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:35 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:35 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:34 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:34 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:33 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:33 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:32 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:51:32 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:53 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:53 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:52 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:52 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:51 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:51 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:50 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:50 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:31 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:31 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:30 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:30 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:29 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:50:29 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:23 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:23 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:22 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:22 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:21 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:21 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:20 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:20 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:19 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:19 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:15 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:49:15 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:12 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:12 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:11 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:11 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:10 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:10 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:09 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:09 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:08 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:08 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:07 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:07 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:06 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:06 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:47:05 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:27 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:27 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:26 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:26 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:25 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:44:25 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:54 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:54 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:53 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:53 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:52 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:43:52 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:39:34 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:39:34 | info | hostapd[1106] | Station 8c:70:5a:47:b9:ac had an authentication failure, reason 17 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:38:54 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:37 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:02:36 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:00:48 | debug | clusterd[1114] | dman sent notification that config has changed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 01:00:48 | info | dman[874] | The AP startup configuration was updated successfully. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | The wireless client with MAC address 68:09:27:a0:0c:6e has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | wlan0: WPA STA 68:09:27:a0:0c:6e pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:50:07 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:57 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:53 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:21 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:37 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:37 | info | hostapd[1106] | wlan0vap1: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:37 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:21 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:37 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:21 SSID Guest-Access | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:29 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:23 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) (PMKSA cache) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:23 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:23 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:23 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:49:23 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:49 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:49 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:48 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:48 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:47 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:47 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:45 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:45 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:44 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:48:44 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:34 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:34 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:33 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:33 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:29 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:35:29 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:22:50 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | The wireless client with MAC address 34:51:c9:c8:f6:60 has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | wlan0: WPA STA 34:51:c9:c8:f6:60 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 9 2013 00:03:38 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:59:13 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 disassociated from BSSID d8:67:d9:d1:e9:20 reason 8: Sending STA is leaving BSS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:42 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:42 | info | hostapd[1106] | The wireless client with MAC address 34:51:c9:c8:f6:60 has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:42 | info | hostapd[1106] | wlan0: WPA STA 34:51:c9:c8:f6:60 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:42 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:41 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:58:41 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:48:07 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:48:07 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:48:06 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:48:06 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 3: STA is leaving IBSS or ESS | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:47:47 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:47:46 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:23:48 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:24 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:23 | info | hostapd[1106] | The wireless client with MAC address 34:51:c9:c8:f6:60 has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:23 | info | hostapd[1106] | wlan0: WPA STA 34:51:c9:c8:f6:60 pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:23 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:23 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 34:51:c9:c8:f6:60 associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:07:23 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 34:51:c9:c8:f6:60 BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:43 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:05:39 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:05 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:02:04 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:21 reason 1: Unspecified Reason | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:56 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:56 | info | hostapd[1106] | wlan0vap1: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:56 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:21 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:56 | info | hostapd[1106] | wlan0vap1: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:21 SSID Guest-Access | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:48 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac deauthed from BSSID d8:67:d9:d1:e9:20 reason 4: Disassociated due to inactivity | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:42 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:42 | info | hostapd[1106] | The wireless client with MAC address 8c:70:5a:47:b9:ac has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:42 | info | hostapd[1106] | wlan0: WPA STA 8c:70:5a:47:b9:ac pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:42 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:41 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 8c:70:5a:47:b9:ac associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 23:01:41 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 8c:70:5a:47:b9:ac BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | authenticated - identity '' EAP type: 25 (PEAP) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | The wireless client with MAC address 68:09:27:a0:0c:6e has been successfully authenticated. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | wlan0: WPA STA 68:09:27:a0:0c:6e pairwise key exchange completed (WPAv2) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | EAP authentication with the authentication server completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | wlan0: IEEE 802.11 STA 68:09:27:a0:0c:6e associated with BSSID d8:67:d9:d1:e9:20 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jun 8 2013 22:59:45 | info | hostapd[1106] | wlan0: IEEE 802.11 Assoc request from 68:09:27:a0:0c:6e BSSID d8:67:d9:d1:e9:20 SSID ADRJSLEDFIWMDWOQFDFPE |
