Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
2181
Highlighted
Beginner
WAP321 Radius auth for captive portal
Hi there,
I'm fighting for a gew days now to setup the captive portal of 2 wireless access point WAP321. I was able to make it work with local user auth but now, I want to manage my guest users on active directory.
So I setup the captive portal to auth user with NPS on Windows 2011 SBS.
The probleme is that my guest SSID in not encrypted, so the NPS server do not let me login.
I try to setup the NPS server like that :
Uncrypted authentification (PAP, SPAP)
Service-Type : Login
Thanks for your help
Everyone's tags (4)
2 REPLIES 2
Beginner
Hi Davy,
We would need to have more info in order to assist you with this issue.  Could you please call at 1-866-606-1866 and we will open a ticket for you and assist you further.
Thank you.
Beginner
Hi Davy,
I am also trying to xcreate captive portal for Outdoor AP (AP 1550 series) Wi-fi Users on the ASR 1006 Router which will redirect the session to Access Registrar, so would you please send me configuration from the ROuter you created please!
Best Regards
Tural
