Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
969
Highlighted
Beginner
WAP321 severe packet loss with Intel 2200 series cards
I am having severe packet loss issues with my WAP321s and Intel wireless adapters, specifically 2200bg, 2200n, and 2230n. I get occasional complete dropouts for over 1 minute at a time, and average of 30% packet loss on a ping test (varies from 10% to 50% on shorter tests).  I have a total of 8 WAP321 in a cluster with single point setup, but I have tested a single AP separate from the cluster with identical results.
Things I have tried on WAP321:
Set radio to b/g only, set radio to n only.
disabled QoS and WMM
disabled WPS
disable Bandwidth utilization
change fragmentation and RTS thresholds.
change transmit power
change beacon interval
tried unsecured as well as WPA2-Personal
20Mhz channel width and 20/40.
Things I have tried on the Intel cards:
disable power management
disable n mode
change transmit power settings
change roaming aggressiveness
disable bluetooth AMP
channel 20Mhz or Auto
3 different Intel Drivers including current 16.1.1.
Has anyone had any experience with this combination of hardware, and do you have any solutions?
Thanks.
Everyone's tags (2)
