WAP371 - ASA5506 - Public Wifi Captive Portal not working
Marc Lawson
So need some assistance....WAP371 with two ssid's: public and private....private vlan1 and public vlan 2....wap371 connected to netgear switch with tagged vlan enable...netgear plugged into asa5506...asa5506 configured to accept both vlans...with public access to  internet only....private access to all.  Everything works great as is but when I enabled the captive portal on the wap371 for the public wifi it does not work and they have not internet access.   It is not the wap371 because if I remove the vlans and connect to the public ssid the captive portal works so it tells me that (I think)  the asa is somehow not allowing that traffic back to the CP when the vlans are enabled.  Any ideas?
ajpareek
Please ensure that WAP371 is running on latest version 1.3.0.7 of firmware; if not i recommend to upgrade the firmware of the device once and check then. Please find the below URL to download the latest version of firmware :
https://www.cisco.com/c/en/us/support/wireless/wap371-wireless-ac-n-dual-radio-access-point-single-point-setup/model.html#~tab-downloads
If you suspect that there is issue with ASA device then you can contact us to open a case for immediate assistance. Please find the link of cisco support contacts below :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html
Ajay Pareek
