Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
374
Highlighted
Beginner
WAP371 not clustering
Hello to everybody
I am trying to cluster my four new WAP371-E-K9 V03 to replace the oldest Cisco AP541N cluster but thet don't want to cluster.
I used last firmware 1.3.0.7 and they don't cluster
I reverted back to 1.3.0.4 and they still don't cluster
I made a reset to factory defaults and still nothing
They are both on same IP subnet and same switch (HPE 1920 8p POE)
I have to admit that for a couple of times I saw them paired in cluster (but any configuration transfered one from the other), then did a refresh and they not were anymore
With the old AP541 (on same switch on same subnet) never had any problems.
Quite often on the access point page under SIngle Point Setup I have this error (that sometimes disappear after refresh, sometimes not)
The following error(s) have occurred...
error occured for query on path cluster.NodeStatusMonitor.getStatus (function: data_service, file: /tmp/11267622_RELEASE_CUST_CISCO_UMR4_1.3.0.4/cbt53016eap/uap/ap/broadcom/src/web-ui-framework/data_service.c, line: 481)
activator_execute: connect to /var/clusterd.socket failed: Connection refused (function: activator_execute_buffer, file: /tmp/11267622_RELEASE_CUST_CISCO_UMR4_1.3.0.4/cbt53016eap/uap/ap/broadcom/src/web-ui-services/activator_query.c, line: 67)
Are there any suggestions?
thanks in advance
massimiliano
1 REPLY 1
Highlighted
Beginner
Re: WAP371 not clustering
Solved.
Old Cisco AP541 cluster broadcast were disturbing the new WAP371 clustering (but not the opposite)
So documentation should add not only that cluster works between same AP models ... but also not having any other old Cisco model bothering on same network
