04-07-2011 09:28 AM
Hi all,
i have WRT120N and WAP4410N, can i config WAP4410N to be repeater to repeat signal from WRT120N??
if it can't, could you tell me what kind of wireless router that compatible with WAP4410N?
thanks so much..
Solved! Go to Solution.
04-14-2011 02:16 PM
Hi Leonardus,
Only to complement the answer.
You can user the WRVS4400N router to be repeated by the WAP4410N.
Regards.
Andrey Cassemiro.
04-14-2011 12:35 PM
Hi Leonardus,
Do you have the equipments?
If don't, you can use the Linksys WRE54G to repeat the Signal.
If you have, did you try to do a Lab? I know that WAP4410N works with Repeater Mode, but i'm not sure about the importance of the router on that.
Regards.
Andrey Cassemiro.
04-14-2011 02:16 PM
Hi Leonardus,
Regards.
Andrey Cassemiro.
