07-03-2012 11:27 PM
We have deployed 2 WAP4410N Access Point in an office environment. Both have been set using the same SSID to allow roaming between the two APs. The client has mostly Macintosh computers which only have the Airport and no LAN connection on them. The setup was working working but then a few days later, the macs start loosing connection to the network although still remain connected to the AP. The issue is resolved by restarting the AP and the same issue occurs afterwards. Any help?
07-06-2012 05:23 AM
i have the same issue, any luck in finding a solution ?
i have 5 Access Points i recently purchased and i am thinking of replaceing them all.
08-15-2012 06:59 AM
I have same issue with this AP. After some hours of working, the client devices losts connection with AP. Very long ping (up to 30 sec). Power off only can help.
08-16-2012 04:14 AM
Hi All,
Have you any DHCP poll? have you checked with Windows PC?
08-16-2012 04:23 AM
AP have a static ip-address in service vlan. Clients obtain addresses from DHCP server.
For this AP clients are Windows, Linux and Android phones.
08-16-2012 04:30 AM
Can you share AP configuration for more detail ?
And you can configure -
increased the Key Renewal setting to 36000 seconds (ten
hours) and it seems that the AP is more stable that way.
I hope i will help you.
08-17-2012 03:44 AM
10-30-2012 02:33 PM
There is a previous forum that contains information useful about this issue.
Let me share with you the link:
https://supportforums.cisco.com/message/3677115#3677115
I hope this information helps you.
Best regards.
Juan Diego Rodriguez
Cisco network engineer
