WAP4410N - Repeater mode problem
Hi  , I got cisco  WAP4410N access point to use it as a repeater , I
set the same authentication, encryption and channel , then i went to
Repeater mode with site survey and choose my router's SSID and mac
address .... the signal is not repeated .. and the traffic is not
forwarded  to the router ...  and i get 2 SSIDs broadcasted one for the repeater  with limited access that cant reach the router , and the other is for my  router with alittle lower signal   but cant reach the repeater .. i  reset the configurations many times and tried to write my router's mac  address manualy at the repeater mode .. but still doesn't work .... i  tried 3 routers with the same problem .. I upgraded the firmware with the same problem .  any help?
I Fixed that issue by making my net work non secure  or by WEP  only  but WPA and WPA2 is not working ...... and now at repeater mode connection is drooped after few seconds and i have to restart the AP .. then it works for few seconds again then drop the connection .. i have the latest firmware what should i do ?
