Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
1305
Highlighted
Beginner
WAP4410N with Radius on non-domain machines
Hi There,
I have configured an SSID using RADIUS as authentication from a win2k8 R2 DC. Connecting from a domain-joined machine with a user already logged in works fine, but the issue we have is from non-domain machines (including iphones & blackberries) is it won't prompt for domain credentials. where/how can I configure this on the WAP/NPS?
Thanks for your help
Ben
Everyone's tags (2)
1 REPLY 1
Frequent Contributor
Re: WAP4410N with Radius on non-domain machines
Ben,
When using Radius authentication, The only thing under the wireless settings when using radius authentication the Radius server ip and pre-share key.When wireless is setup for radius authentication all the router is doing relaying that information to and from your radius server. The problem isn't going to be with router; you will need to look at radius server and host authentication configuration.
Jason Bryant,
Cisco Support Engineer
