Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
565
Beginner
Wireless Access Points Hooked up to RV320
We have a office network setup to support up to 20 staff.  I'd like to add wifi access to our office network and looking for a reliable Wireless Access Point that can be plugged directly into the RV320 without additional controllers or hardware in between.
We've looked at the Aironet 1700 & 2700 and unsure if these models work directly with the RV320 without additional controllers.  Does anyone know first hand?
http://www.cisco.com/c/en/us/products/wireless/aironet-1700-series-access-points/index.html
http://www.cisco.com/c/en/us/products/wireless/aironet-2700-series-access-point/index.html
Everyone's tags (2)
3 REPLIES 3
Beginner
Thanks for contacting Cisco,
Thanks for contacting Cisco, let me share with you the contact information to a specialized department that can provide you the accurate information to your inquiry, find below the contact information.
Get Presales Help
Participant
Hi, you might wanna look at
Hi, you might wanna look at the WAP300 series (for example WAP 371), these should work perfectly fine for your use case. However, to power them you would still need a power adapter with each access point or put a simple SG100 POE switch in between RV320 and the WAP AP's ;)
Highlighted
Beginner
I would say WAP361/571 should
I would say WAP361/571 should be good enough for you. Both of them need POE+ power source. Instead of  POE switch you can use Cisco power injector - SB-PWR-INJ2-xx.
