Wireless implementation
Hello to you. I like the project to install wifi access point in a building.
I possess a switch Catalyst WS-c2960X-24PS-L and a controller wifi cisco 2500 series AIR CT2504-15-K9.
Since the place is very strategic and sensitive, I would like to know if it is essential to reference wifi access points AIR-CAP2702-E-K9.
What do you think?
Eric Moyers
Level 7
Level 7
Depending on the size of your deployment and any specialized needs, you could also look at the AIR-AP1852E-UXK9.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/datasheet-c78-734256.html?cachemode=refresh
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Eric Moyers
Level 7
Level 7
Eric Moyers
I'll also try this option.
Hi Eric and thank for your proposition (AP1825-UXK9).
through this, I could diversify the different wireless scanning requirements and other.
